Tuya Zigbee Water Sensor Flood Leak Detector App Remote Monitoring for Kitchen/Bathroom Support Home Assistant Smart Life
$8.09
Color: 1Pc Zigbee
Attention please:
This is the Zigbee version and requires a gateway for connection!!!
Why buy?
The Tuya ZigBee Water Sensor Leak Detector is a smart, wireless flood detection device designed to protect your home from water damage. It instantly alerts you via the Smart Life App when water leakage is detected, allowing you to take quick action to prevent costly damages. Compatible with ZigBee gateways, it integrates seamlessly into your smart home security system for real-time monitoring and notifications.
1.Instant Leak Detection – Detects water leaks and floods early to minimize damage.
2. Smart Alerts – Receive real-time notifications on your phone via the Smart Life App.
3. ZigBee 3.0 Connectivity – Works with Tuya ZigBee gateways for stable, low-power wireless communication.
4. Easy Installation – Compact, wireless design with a peel-and-stick base for quick setup.
5. Low Battery Alert – Notifies you when the battery needs replacement.
6. Smart Home Integration – Compatible with Amazon Alexa, Google Assistant(via gateway).
Q&A
1.How to connect Water Sensor?
This Water Sensor connection requires Tuya zigbee gateway, the gateway is powered on, the product on the battery, the product should be as close as possible to the Zigbee smart gateway, and then long press the product reset button for 6 seconds until the indicator light flashes quickly, open the smart life or Tuya APP, click on the upper right corner of the “+” sign, click on the add device, and wait for the search to be added!
Specification
Product Name:Water Sensor
Product Size:50X16mm
Working Temperature:0°C~+55°C
Connection Method:ZigBee
Battery Type:CR2032
Package Included:
Water Sensor*1
Manual*1
