Works with Smartthings HomeKit Alexa Google Tuya Smart Standard ZigBee3.0 Water Leakage Detector Flood Sensor APP Remote Control
  • Reliable Leak Detection: Our Smart Water Leak Detector identifies even the smallest water leaks, providing early warnings to safeguard your property
Shop Zigbee 3.0 Smart Home Flood Detector With Instant Leak Alerts via App
Protect your home from potential water damage with our Smart Home Flood Detector. This advanced Flood Sensor is designed to detect water leaks promptly, ensuring you receive immediate alerts to prevent costly repairs.
  • Reliable Leak Detection: Our Smart Water Leak Detector identifies even the smallest water leaks, providing early warnings to safeguard your property.
  • Integrated Temperature Sensor: Beyond detecting water, it also monitors temperature variations, offering additional insights into your home's environment.
  • Loud Alarm System: Equipped with an 85 dB built-in siren, it ensures you're promptly alerted to any water detection, even if you're not nearby.
  • Extended Battery Life: Designed for longevity, the device boasts a battery life of up to 5 years, reducing the need for frequent maintenance.
  • Zigbee 3.0 Compatibility: Seamlessly integrates with various Zigbee-based systems, enhancing your smart home's connectivity.
Place the Flood Sensor in areas prone to leaks, such as under sinks, near water heaters, or behind appliances like washing machines. Its compact design allows for discreet placement, ensuring continuous monitoring without disrupting your home's aesthetics.
  • Prevent Extensive Damage: Early detection allows for swift action, minimizing potential water damage and associated repair costs.
  • Peace of Mind: With real-time alerts sent directly to your smartphone, you can rest easy knowing your home is under constant surveillance.
  • Enhanced Home Safety: By monitoring both water leaks and temperature changes, the device offers a comprehensive approach to home safety.
Additional Information
For hard-to-reach areas or places with a high risk of flooding, consider using the optional probe extension. This accessory allows the Smart Water Leak Detector to monitor areas like basements or beneath appliances more effectively, ensuring comprehensive coverage.
