X10 Plug-In Dimmable Lamp Module
$22.95
The X10 Plug-In Dimmable Lamp Module is a versatile and easy-to-use device that allows you to control the brightness of your lamps with just a few clicks. Simply plug the module into any standard wall outlet and plug your lamp into the module. You can then use an X10 controller to easily adjust the brightness of your lamp, from fully illuminated to a soft, cozy glow. The module also has a built-in soft start feature that gradually increases the brightness of your lamp, helping to extend its lifespan. With its compact design and simple setup, the X10 Plug-In Dimmable Lamp Module is the perfect solution for creating personalized lighting ambiance in any room of your home.
