Zigbee 3.0 Temperature Humidity Sensor Thermometer Hygrometer Digital Screen IP65 Waterproof Optional Work with Alexa Yandex Z2M
$13.18
Color: No Waterproof
Product name : Zigbee temperature & humidity sensor
Wireless Protocol: Zigbee 3.0
Voltage: DC 3V
Battery: LR03-1.5V/AAA*2(Not included)
Material: ABS
Temperature range: -20C~60C
Temperature resolution: ±1°C
Humidity range: 0%-100%RH
Humidity resolution: 5%RH
*How to use this product ?
Answer: Please use it with one zigbee gateway . It cannot work alone without zigbee gateway.
*How is the temperature and humidity display on app ?
Answer :If using Tuya Zigbee gateway, the temperature and humidity units of the app are accurate to 1 ° C or 1% without a decimal point.
If using for Yandex Alice Gateway /for Alexa Echo Gateway etc. ,the temperature and humidity units of the app can be accurate to 0.1 ° C or 0.1%.Please understand.
*Is it compatible with Zigbee2mqtt on home assistant?
Answer: Yes,you can add device on zigbee2mqtt via related gateway.
*Can it work with alexa or google home voice control ?
Answer : If you link device to alexa via tuya app or smart life app ,tuya or smartlife app may not have entrance.Suggest you can pair sensor with alexa ( built-in zigbee 3.0 hub) ,or google home assistant (built-in zigbee 3.0 hub)or yandex alice (built-in zigbee 3.0 hub) ,then use voice control .
