Zigbee Ewelink Water Level Sensor Smart Home Water Leakage Alarm Detector Flow Sensors Flood Alert Overflow Security Protection
Features:
1.Instant water leakage alarm: Equipped with a highly sensitive water sensing probe, it can instantly send an alarm to your phone
2.Zigbee3.0 intelligent interconnection, used in conjunction with the yiweilian intelligent gateway, easily realizes smart home systems, remote monitoring, intelligent scene linkage, and other functions, such as automatic water source valves or starting drainage pumps
3.Comes with double-sided tape for easy installation, no wiring required, and can be applied immediately
4.Low battery reminder, when the battery is low, it will automatically remind you to replace the battery
5.Wide range of use: Suitable for kitchens, bathrooms, basements, laundry rooms, etc
Parameters:
Product type: zigbee intelligent water level detector (yiweilian)
Voltage: dc3v
Low voltage indication:≤2.5v
Static current:≤10ua
Alarm current:≤15ma
Zigbee: 2.400ghz-2.484ghz (gateway required)
Working temperature: 10~+50℃
Working humidity: maximum 95% rh
Product size: 69*24*16mm
Package include:
Detector*1
Instruction manual*1
Double sided adhesive*1
Accessory package*1
