Zigbee Soil Moisture Sensor Temperature Humidity Meter Fertility Lux Light Tester for Tuya Smart Life Zigbee2Mqtt Home Assistant
$33.02
Color: Tuya Zigbee(4 In 1)
What is the difference between two version ?
*4 In 1 Zigbee2mqtt : Zigbee hub required.Can only work with Zigbee 2mqtt in home assistant,not work for ZHA.
*4 In 1 tuya Zigbee: Zigbee hub required.You can use it with tuya zigbee gateway (Using tuya app/smart life app). Support work with Zigbee 2mqtt on home assistant. Not work for ZHA.
*5 In 1 Zigbee2mqtt : Zigbee hub required.Can only work with Zigbee 2mqtt in home assistant,not work for ZHA.
*5 In 1 tuya Zigbee: Zigbee hub required.You can use it with tuya zigbee gateway (Using tuya app/smart life app). Support work with Zigbee 2mqtt on home assistant. Not work for ZHA.
Note: Not support voice control
Parameters
Item: Zigbee Soil Moisture Humidity Temperature Tester
4 In 1 function : Soil moisture detection +Air temperature + Air Humidity + Luminance Detection
5 In 1:Air Temperature / Air Humidity/ Soil Moisture/ Luminance/soil fertility
Battery Type: 2 x LR03 AAA(not included)
Wireless Protocol: Zigbee 3.0(need zigbee gateway)
Soil Moisture Range:0%~100%
Soil Moisture resolution: 3%
Temperature Resolution: 0.1℃
Humidity Resolution: 3%
Light intensity Resolution: 1lux (only 4 in 1 version )
Temperature Measurement Accuracy: ±0.5℃
Humidity Measurement Accuracy: ±5%
Working Voltage: DC3V
Standby Current: ≤20uA
Do not support for alexa or google assistant voice ,no voice control .
