Zigbee Temperature and Humidity Sensor Smart Home Connected Thermometer Compatible with Alexa Google Assistant Yandex Alice Z2M
Zigbee Temperature And Humidity Sensor Smart Home Connected Thermometer Compatible With Alexa Google Assistant Yandex Alice Z2M
1.Real-time perception of temperature and humidity changes and real-time report to your smart phones with eWeLink App supported. View history record in App for smart controls for your house temperature and humidity. Monitor your house temperature and humidity no matter where you are.
2.eWeLink Smart ZigBee Temperature and Humidity Sensor: A eWeLink ZigBee Gateway Hub is a must to work with the temperature and humidity sensor, as well as a variety of ZigBee smart products, which is proved to be the bridge and control center for smart homes and plays an irreplaceable role for all ZigBee products and realizes the whole intelligent linkage of your house. Simply add the sensor into the ZigBee hub after adding the hub into eWeLink App.
3.New ZigBee technology with low power consumption microprocessor for long standby. Designed with low voltage monitoring reminder function in App for real-time power supply for your sensor. Battery powered with long battery life.(battery NOT include)
4.Widely used in various places and easily stick it to the wall with the sticker for simple installation, light and compact.Easy set up and configure to your eWeLink App for convenient control.
5.New added with temperature compensation technique with smart scene linkage to your air conditioning and humidifier, offering your house with the most comfortable temperature and humidity to enjoy our life.
6.Compatible with Alexa and Google home,Yandex Alice.
Wireless Protocol: Zigbee 3.0(need zigbee gateway)
Temperature Resolution: 0.1℃
Humidity Resolution: 1%
Temperature Measurement Accuracy: ±0.3℃
Humidity Measurement Accuracy: ±3%
Working Voltage: 3V
Standby Current: ≤5A
Battery Type: CR2450(include battery)
App: eWelink(not smart life)
