Zigbee Weather Station Digital Thermometer Room Tuya Smart Hygrometer Electronic Table Clock Temperature and Humidity Sensor
Voltage: DC 5V
LED indicator: Blue
Wireless Connection: 2.4GHz 802.11b/g/n
Temperature measure range: -10℃~65℃
Temperature correction range: -2℃~2℃
Humidity measure range: 0% ~ 99%RH
Humiditycorrectionrange: -10%~10%RH
Package List:
Weather Station*1
Retail Box*1
Manual*1
Charging Cable*1
Features:
ZigBee Temperature And Humidity Sensor
With Backlight/Real-time monitor/Work With Zigbee Gateway
Temperature And Humidity State
The icon display,real-time display of the current temperature and humidity
All Weather Test And Alarm
Instantly sends notification when the data of temperature and humidity goes beyond preset range.
Smart Linkage With Other Devices
Can be used as trigger for other devices.You can create the instruction like this:
If the Humidityis>68% then turn on the humidifier.
If Temperature>28℃ then turn on the air conditioner.
Real-time monitor
High accuracy(humidity accuracy:±5%RH, Temperatureaccuracy:±1℃),
supporting manual correction.
Backlight Supported
Press the button, the backlight wil be turned on and last for about 10 seconds.
Data Storage And Export
most accurate enough to view hourly data, check the highest and lowest values at any hour or day and data can be exported as files
Rotating Storage Type-C
Can be placed on the desktop/hanging on the wall/UseType-C data cable.
Multi Power Methods
With our C-smart series switches or sockets,no data line is required.
More Functions
C And °F Switch/Offline Notification/Share Device/Create Group
