10M 20M Tuya Zigbee DC24V CCT COB LED Strip Linear Lights 3Wire 608Leds/M 2700K-6500K Dimmable APP Remote Control Room Decor
$85.32
Emitting Color: 5M Full Kit
Note: the controller is zigbee,not wifi,need work with zigbee gateway.
Features :
● Used for control single color or color temperature LED strip.
● DC power socket input and 2 channel constant voltage output.
● Tuya APP cloud control, support on/off, color temperature and brightness adjust, delay turn on/off light,
timer run, scene and music play function.
● Match with RF 2.4G remote control optional.
● User need set light type by press key before Tuya APP network connection and match RF remote of the same light type.
● Each WZ1 controller can also work as ZigBee-RF converter, then use Tuya APP to control one or more RF LED controller
or RF LED dimming driver synchronously.
● Connect with external push switch to achieve on/off and 0-100% dimming function.
Specification:
- Input voltage: 12-24VDC
- Output type: constant voltage
- Output current: 2CH, 5A/CH,
- Output power: 2x (60-180)W
- Dimming range: 0-100%
- Remote distance: 30m
- input signal:APP+ RF 2.4Ghz
led Specification:
Color temperature: CCT
Power: 14w/m(7W+7W)
Number of LEDs: 608led / M
Voltage: low voltage 24V
Width: 10mm
PCB board color: white
Installation method: adhesive type, 3M high adhesive backing
Applicable occasions: home decoration, shopping malls, municipal administration, hotels, KTV, interior decoration, Internet cafes, etc
The package includes:
1 * 5M set (one roll 5m)
1 * 10M set (one roll 10m)
1 * 20M set (2roll 10m)
