1m-10m WIFI RGB 5050 Bluetooth LED Strip Light with USB Line, Music Sync 5V Flexible Ribbon Alexa Smart Lamp for Party Room Deco
Luminous Flux: 249-2000
Hign-concerned Chemical: None
Is Smart Device: YES
Power Generation: SWITCH
Model Number: 5050 wifi
- Luminous Flux: 249-2000
- Hign-concerned Chemical: None
- Is Smart Device: YES
- Power Generation: SWITCH
- Model Number: 5050 wifi
- LED Chip Model: SMD5050
- Certification: ce,FCC,ROHS,UL
- Power Source: DC
- Origin: Mainland China
- Strip type: SMD
- Occasion: bedroom
- Item Type: Strip
- Brand Name: suitsamus
- Voltage: 5V
- Waterproof: No
Please notice before ordering
If you choose “bluetooth” one , it doesn't support wifi voice contorl. You can only connect bluetooth. App NAME IS "happylighting"
If you choose WIFI version, APP name is "CozyLife", which supports voice control
Why choose our products?
【About item】It is easy to connect, there are 3 ways to control, 16 millions of colors, long lifetime 50,000 hours, Ultra-bright and dimmable, DIY function, timer setting , music mode ect.
【About delivery】All items are in stock, it will be shipped in 24 hours except every Sunday
【About after sales】90-day buyer protection, money back guarantee.
【About promotion】every $15 enjoy $1off, any two items enjoy 2% off. dropshipping is welcomed.
【About power supply】Default sent EU Plug, if you need US /AU/UK Plug, please contact us or add a note when placing an order.
WIFI One Supports Voice Contorl
APP contorl
Wifi APP name is "CozyLife", available in Google play or App store.
Bluetooth app name is " happylighting"
5050 High Quality LED Beads
This led strip use good high-quality LED beads, which will be more bright, and it will have longer lifespan.
Easy to cut
You can cut it every 3 led beads, and when you connect the led strip, please connect it "arrow to arrow"
Music mode=Romantic time
a not expensive strip make your dating more romantic
Timer Setting
You can set a timer to turn on/off the lights with your favorite color, you can also control the light strips within responsive distance of 50ft via the phone app
How to Connect the App
Step 1: Download “CozyLife” APP;
Step 2: Click on the top left corner of the app to add a device and select add "Wifi device". And click "Next” to enter the wifi setting page.
Step 3: Enter your home WIFI password and click "OK"
Step 4: Follow the prompts to continue
Step 5: Name your strip light with English words only
There are instructions in the package, if you encounter difficulties during the connection process, you can contact us at any time
When the light strip is used for the first time, it enters the initialization state by default and can be directly connected to the app.
If you need to replace the new mobile phone to control this light strip, you can repower-on the light strip 3 times to enter the initialization state.
Suitable for Any Scenarios
