2GIG Flood and Temperature Sensor 345 MHz
The 2GIG Flood and Temperature Sensor 345 MHz is a fully supervised, tamper-protected one-way 345 MHz sensor. Its Water Leak Sensor will monitor the ambient temperature and ambient temperature and will detect a wet/dry flood condition in Ezlo. The Wi-Fi Water Sensor reports wet/dry conditions and temperature to your Ezlo Secure gateway. Once the sensor probe detects the presence of water for three (3) minutes, the integral transmitter will send a wet alarm transmission to the security/control panel. The probe will also send a restore (dry) report when the presence of liquid is no longer detected by the flood probe for three (3) minutes. For flood reporting, the sensor requires the installation of the supplied external flood probe. The Water Leak Sensor is capable of detecting clean or dirty fresh, salt water, or tap water.
Compatible with:
- Ezlo Secure
- Vera Secure
