2GIG Thin Door Window Sensor 433 MHz
The 2GIG Thin Door Window Sensor 433 MHz is designed for use on doors, windows, and other objects that open and close. It communicates with your Vera Secure Gateway by using the 433 MHz frequency. When the magnet (which is mounted near the sensor) moves away from or closer to the door contact’s sensor, signals are transmitted to your Vera Secure gateway.
