5.8G 24G Zigbee Human Presence Sensor Detector Radar Wave Detection Sensor for Home Security Tuya Smart Human Body Exists Sensor
Main Features:
1.Functional Wifi/ZigBee Smart Human Presence Sensor
2. Perceived Light Intensity for Smart&Scene Linkage
3.Two Models Are Available
The ceiling mount can be installed like a downlight, which can be powered directly by AC; the wall mount can be attached to the wall or wherever you need it. It's as light as a wireless hub, and it's powered by USB 5V.
4. Advanced New Design with Multiple Settings
Set the sensitivity from 1-9 to your own need,together with minimum detect range as 0.00m and maximum as 9.5m for flexible detection demand.Meanwhile,it is designed with hold time set as 0-1500s and detection latency set as 0-10s to avoid irrelevant annoying movement and reduce false alarm rate.
5. ZigBee Hub as Control Center
Tuya ZigBee gateway is required for this ZigBee human presence sensor,performing as the center bridge for all Tuya ZigBee smart devices with extremely stable signal and a really good necessity for whole-house intelligence.(note:Tuya ZigBee hub is highly recommended for its wider compatibility than other hubs)
Network: ZigBee / Wifi.
power supply: USB 5V1A(Without plug)
Working temperature: -20℃~+70℃
Sensitivity: 1-9(default 7)
sensing distance: 0.3-9m(Default 6m).
Illuminance Sensor: 0-2000 LUX.
Target detection confirmation time:0-10s
Target disappearance delay time:2-1500s.
Wall Mount Size: 43*43*15mm
Package list:
Human presence sensor*1
User manual*1
USB Cable*1
