Abjf-Tuya Zigbee Water Sensor Alarm for Home, Detect Leaks & Full Water Tanks with APP Control
Advanced Water Detection Technology: The smart water sensor uses the latest ZigBee protocol to quickly detect water leaks or flooding and immediately sound an alarm to prevent potential flooding
Remote Monitoring: Stay up to date wherever you are. Using the Tuya Smart or Smart Life App, you can remotely monitor your home security and receive instant notifications on your smartphone
Easy Installation: This compact wireless sensor can be placed at any potential water leak point, such as under the sink, near the washing machine, or in the basement. No tools required, just place and connect
Long-lasting battery life: Designed for durability and long-term use, the sensor operates efficiently and requires minimal maintenance to give you peace of mind
Home Automation Compatibility: Seamlessly integrates with your existing smart home setup and is compatible with a variety of ZigBee hubs to create a smarter and safer home environment
Wireless Protocol:Zigbee3.0
Working Voltage:3V
Battery Type:CR2032
Standby Current:Less than 8uA
Working Temperature:-10 - 55℃
Waterproof:IP66
Frequency Band:2405-2480GHz
Maximum Radio Transmit Power:Less than +10dBm
Color: White
Material: plastic
Package Contents:
1 * Smart Water Sensor
Working Voltage:3V
Battery Type:CR2032
Waterproof:IP66
Color: White
Material: plastic
Package Contents:
