Aeotec Smart Switch 7
Regular price $66.99
Regular price $66.99 Sale price
Shop Aeotec Smart Switch 7 at Best Price
The Aeotec Smart Switch 7 is a versatile and reliable device that allows you to control your home’s electrical appliances from anywhere, at any time. With its sleek and compact design, this smart switch seamlessly blends into any home decor while providing advanced automation features.
Compatible with a variety of smart home systems, including Z-Wave technology, the Aeotec Smart Switch 7 integrates effortlessly with your existing setup. It also features energy monitoring capabilities, enabling you to track your electricity consumption and save money on your bills. With the Aeotec Smart Switch 7 Home Assistant, you can gain valuable insights into your energy usage patterns and optimize your home’s efficiency.
Installation is a breeze thanks to its simple and intuitive design. Just plug it into a standard wall outlet and connect your appliance to it. You can then use the accompanying mobile app to turn your devices on or off, set schedules, and even create custom scenes. The smart switch 7 aeotec ensures that managing your home’s devices is both convenient and user-friendly.
Equipped with overload protection, the Aeotec Smart Switch 7 ensures that your devices are safe from power surges and electrical damage. Whether you’re looking to control your lights, fans, or other appliances, this smart switch is the perfect solution for your smart home needs. Enhance your home automation experience with the Aeotec Smart Switch 7 and enjoy the benefits of modern technology in a compact and stylish package.
Manufacturer Part #: ZWA023
Repeater: Yes
Beaming: Yes
Frequency: 908.42 MHz
Wireless Range: Indoors: 114 feet (35 m)
Outdoors: 492 feet (150 m)
Security: Non-Security, S0, S2 Authenticated
Input Voltage: 100 – 240 VAC 50/60Hz
Working Current: 7mA
Standby Current: 4mA
Max. Momentary Load: 135V, Max: 15A, 2025W
Max. Continuous Load: Resistive: 120V 60Hz, Max: 15A, 1800W
Inductive: 120V 60Hz, Max: 10A, 1200W
Capacitive: 120V 60Hz, Max: 8A, 960W
Max Standby Power: 0.6W
Minimum Energy Sensor Reading: 2W
Energy Reading Percentage of Error: Less than 300W: ±3W
Greater or equal to 300W: ±1%
Waterproof Rating: IP20
Operating Temperature: (32°F to 104°F) 0°C to 40°C
Relative Humidity: 8 to 80 percent
Dimensions: 3.5 x 1.4 x 1.3 inches (91.0 x 35.6 x 33.0 mm)
Certifications: Z-Wave Plus, FCC, CE, RoHS, ETL
Warranty: 1-Year Limited
