Aqara Water Leak Sensor E1 ZigBee 3.0 Water Immersing Detector Soaking Sensor Alarm Remote Control Work with MiHome Homekit
  • Immediate Leak Detection: Equipped with sensitive probes, the sensor identifies water levels as low as 0.5mm. Upon detection, it triggers a leak detection alarm, sendi..
  • IP67 Waterproof Rating: Built to withstand humid and dusty conditions, the sensor's IP67 rating ensures reliable performance even in challenging environments
  • Seamless Integration: Compatible with Apple HomeKit and other smart home ecosystems, the sensor allows for customized automation. For instance, it can activate a solen..
  • Wireless and Compact Design: With its sleek and wireless design, the sensor can be easily placed in areas prone to leaks, such as under sinks, near appliances, or in b..
  • Long-Lasting Battery Life: Powered by a CR2032 battery, the device offers up to two years of continuous operation, minimizing maintenance efforts
Shop Aqara Water Leak Sensor E1 Reliable Protection Against Water Damage
Safeguard your home from potential water damage with the Aqara Water Leak Sensor E1. This compact and efficient device is designed to detect the slightest presence of water, providing timely alerts to prevent costly repairs and maintain a safe living environment.
  • Immediate Leak Detection: Equipped with sensitive probes, the sensor identifies water levels as low as 0.5mm. Upon detection, it triggers a leak detection alarm, sending instant notifications to your connected devices.
  • Seamless Integration: Compatible with Apple HomeKit and other smart home ecosystems, the sensor allows for customized automation. For instance, it can activate a solenoid water valve to shut off the water supply when a leak is detected, serving as a remote water leak alarm
  • Wireless and Compact Design: With its sleek and wireless design, the sensor can be easily placed in areas prone to leaks, such as under sinks, near appliances, or in basements.
Place the Aqara Water Leak Sensor E1 in areas susceptible to water leaks, including bathrooms, kitchens, basements, and balconies. In the event of water exposure, the sensor promptly sends alerts, enabling you to take immediate action. Its integration capabilities allow for automated responses, such as turning off water valves or activating alarms, providing a comprehensive remote water leak alarm system.​
By detecting leaks early, this soaking sensor helps prevent structural damage, mold growth, and loss of valuable possessions, ensuring peace of mind and a safer home environment.
