Arlington Combination Mounting Box for Power & Low-Voltage, New Construction
$7.95
The Arlington Combination Mounting Box for Power & Low-Voltage, New Construction is the perfect solution for your electrical installation needs. This versatile box is designed for new construction projects and accommodates both power and low-voltage installations Arlington Power & Low-Voltage Box, New Install. It is made of durable materials that ensure long-lasting use and can withstand harsh environmental conditions.
The Arlington Power & Low-Voltage Box, Retrofit features a unique design that allows for easy installation and wiring, making it a convenient choice for electricians and DIY enthusiasts alike. It also comes with a built-in bracket for added stability, ensuring that your electrical devices are securely mounted. With the Arlington Combination Mounting Box for Power & Low-Voltage, New Construction, you can rest easy knowing that your electrical installations are safe, secure, and reliable.
| Size: | 3.625(H) x 5.360(W) inches |
| Weight: | 0.28 pounds |
| Color: | Black |
| Material: | Plastic |
| Cubic Inches: | 20.2 (Power Side) |
| Fire Rating: | 2 Hours |
| Knockout Sizes: | 1/2" and 3/4" |
| Listing: | UL |
