Arlington The SCOOP Slotted Cable Access Insert
$5.95
The Arlington The SCOOP Slotted Cable Access Insert is the perfect solution for organizing cables and wires in your home or office. Made from durable, high-quality materials, this insert features a slotted design that allows cables to be easily inserted and removed.
The SCOOP can be used with a variety of different cables including power cords, ethernet cables, and HDMI cords. It is also compatible with a wide range of wall plates, making it a versatile addition to any home or office.
The insert is easy to install and can be used with both new and existing construction. It is designed to fit snugly into most standard 2-gang boxes, providing a clean and professional finish.
Overall, the Arlington The SCOOP Slotted Cable Access Insert is a must-have for anyone looking to organize and streamline their cable management. With its durable construction, easy installation, and compatibility with a wide range of cables and wall plates, it is the perfect accessory for any home or office.
