Black Zigbee Smart Fingerbot plus Switch Button Pusher Touch Arms Fingerbot Tuya Smart Life APP Control Works with Alexa Google
Description:
【New upgrade ZigBee version】:Tuya ZigBee Gateway/Hub is required.
【APP remote control 】:The smart fingerbot plus can be controlled by mobile phone connect zigbee gateway.
【Voice Control 】:The smart switch button pusher can be controlled through a voice device at home.
【Timed start】:You can set the time in the APP and start the fingerbot button at a regular time.
【Ultra-long battery life】:The zigbee fingerbot uses the CR2 battery, which has ultra-long battery life.
【Convenient installation】:Stick glue on the bottom surface of the finger robot, paste it in the required position, open the mobile phone APP for configuration and use.
Product Name: Zigbee Fingerbot Plus
Dimensions: 34.5*34.5*34.5mm
Weight: 38g
Battery: CR2 3.0V
Torque: 2.0 kgf.cm
Maximum arm movement: 12mm
Wireless Protocol: Zigbee 3.0
Working Temperature: -10℃—45℃
Zigbee Hub: Required
Package Included:
1*Zigbee Fingerbot Plus
Notes:
1.The zigbee fingerbot plus must be used with tuya zigbee gateway.
2.Work with Home Assistant Zigbee2MQTT and ZHA.
