Chief THINSTALL Swing Arm Display Mount, 18 In. Extension, 10-32 In.
Regular price $144.00
Regular price $144.00 Sale price
Introducing the Chief THINSTALL Swing Arm Display Mount, the perfect solution for anyone looking to elevate their viewing experience. With an impressive 18 inch extension, this mount allows you to position your display exactly where you want it. Designed to fit displays ranging from 10-32 inches, this mount is versatile enough to accommodate a wide range of screens.
Featuring an easy-to-use swing arm design, this mount allows you to adjust the angle of your display with ease. The Chief THINSTALL Swing Arm Display Mount is also incredibly sturdy, with a load capacity of up to 40 pounds. This means you can mount even the heaviest displays with confidence.
Installation is a breeze with this mount, thanks to its simple design and included hardware. Whether you're mounting your display in a home theater, office, or classroom, the Chief THINSTALL Swing Arm Display Mount is the perfect choice. Order yours today and start enjoying the benefits of a perfectly-positioned display!
Product Specs:
Certifications UL
Color Black
Maximum Extension 18 inches (457mm)
Minimum Depth 5 inches (127mm)
Mounting Pattern Compatibility (Universal Versions) 75 x 75, 100 x 100, 200 x 100, 200 x 200mm
Orientation Landscape, Portrait
Overall Dimensions 11.6(H) x 13(W) x 1.5(D) inches (294 x 330 x 38mm)
Pivot ±90 degrees (depending on screen width)
Post-Installation Leveling (Roll) Yes
Weight 8 pounds
Solution Type Universal
Tilt +0 degrees, -12 degrees
Typical Screen Sizes 10 to 32 inches
Wall Stud Compatibility Single Stud
Weight Capacity 35 pounds (15.9kg)
