Cozylife 220V 110V Wifi Smart LED Bulb 12W 15W 20W E27 Cold & Warm Indoor Light Alexa Google Home Together APP Timing Dimming
Regular price $16.19
Regular price $0 $16.19 Sale price
Warm Tip
* 110V voltage suitable for the region: the United States, Canada, Panama, Cuba, Lebanon, Mexico, Japan, South Korea, Taiwan
* 220 Voltage: Most European countries, Singapore, Philippines, Thailand, India, Australia, New Zealand, Egypt, South Africa, Australia, New Zealand.
* The voltage of each region is the standard, please pay attention to buyers to distinguish the specifications.
Specification
*Type: WiFi Smart LED Bulb
*APP name: Cozylife
*Material: Aviation Aluminum, plastic
*Function: WiFi connect, APP control, timer function, dimmable, Compatible with Alexa Echo Google Home Assistant
*Light color: Warm white (2700K) / White (6500K)
*Socket Type: E27
*Power: 12W 15W 20W
*Voltage: AC 220V 110V
*CRI: >85
*Life: >20000h
*Beam Angle: 180 degrees
* Alexa and Google Home Voice Control:
Control your smart bulb via your voice with Google Assistant and Alexa. Support Alexa and Google Home voice control, just give a voice command to turn on/off or dim/brighten your light.
* High Brightness and Energy Saving:
The bulb owns high brightness, Our Smart light bulb using LED rather than incandescent bulbs. It is less energy, produces less heat, good for saving energy.
* Dimmable Brightness:
The light brightness can be fixed percentages from 1% - 100% output, you can set many different scenarios like 'Reading Light' 'Soft Light' etc.
* Wide Usage:
With LED technology, this bulb can be used on anywhere you need light such as home indoor lighting, hotel, meeting room, museum, restaurants, bar, cafe, holiday decoration, birthday party.
* Remote And Group Control:
Keep connecting this wifi smart light bulb with your home network (only supports 2.4GHz Wifi), you can remotely control smart light bulb on your smartphone Simulate when you leave home, there are people in the house. Group control function allows you to control more than one smart light bulb at the same time for scene setting.
Note
* The bulb flickers before use probably because it has not been successfully paired with the cell phone, this is a normal phenomenon, after successfully connecting with the cell phone, the bulb stops flickering and returns to normal.
* When connecting the smart bulb, please make sure you are using 2.4 GHz WiFi and the WiFi must be detectable. Many routers have both 5 GHz and 2.4 GHz networks and your phone will automatically connect to the 5 GHz network. Therefore, you must turn off the 5 GHz network through your router settings before you can connect your phone to a 2.4 GHz network.
* If you do not have 2.4G WiFi at home, you can try to open a hotspot for network sharing through your cell phone.♡
