DC12V Tuya Zigbee LED round under Cabinet Light Kit RGB Color Change Dimming for Kitchen Shelf,Voice Control Google Alexa Echo
$83.27
Color: 2Pcs Rgb Kit
Caution:
1.Zigbee device requires work with Zigbee gateway!!
The zigbee controller in this link work with many gateways like Amazon ECHO Plus , O*sr*am,SmartThings, etc
2.The white color is a mix of red, blue and green light, not pure white color.
Product Description:
▶Here is zigbee version RGB cabinet LED under cabinet light.
▶The RGB color can be changing by APP/Voice control.
▶We provide 2-9pcs kit,you can choose according how many you want.
▶This under cabinet light kit can be widely used in household and residential application like kitchen, under counter, closet, wardrobes, cupboards, dresser, wall, ceiling, cabinet, desk, bed, table, drinks(liquor) cabinet, wine racks, christmas decoration, wine cellars, bar counter under shelf etc.
▶All necessary accessories included: adapter, splitter, extension cables, adhesive tapes, very easy to install and will protect your furniture.
▶The cabinet lamps are made of aluminum alloy, not plastic, providing very good heat dissipation and longer lifespan.
LED cabinet light’s Parameter:
--LED quantity : 5050 RGB SMD LEDS 9LEDs/Light
--Power: 2-2.5W per lamp (12W in total)
--Lumen: 200lm per lamp
--CRI: >80
--Size: D58*H8mm
--Extension cable length:150cm
Zigbee Controller Parameters:
Please kindly note that our zigbee devices require related gateways.
--Model No.:YSR-MINI-Z01
--Voltage: DC5V-24V
--Output: Max. 2A/Channel, Total output Max.5A
--Product Name:ZIGBEE Strip Controller
--Size: 28x24x11.5mm
--Operating Temperature:-20-+60℃
Package Included:
Depending on the number of lights you order.
2pcs Kit:
2x RGB cabinet light
1x Zigbee controller
1x 4 ways splitter box
1x12V power supply
2x 3M adhesive tape
4x screw
7pcs Kit:
7x RGB cabinet light
1x 9 ways splitter box
1x12V power supply
7x 3M adhesive tape
14x screw
