Digital Zigbee Smart/Wifi Room Thermometer Hygrometer APP Alert Temperature Humidity Meter Support for Alexa for Home Pet Garage
Digital ZigBee Smart/WiFi Accurate Hygrometer Temp Meter APP Alert Hygrometer Thermometer Detector Support for Alexa Hygrometer Temperature Gauge LCD Display Remote for Home Pet Garage
Feature:
1. Remote Monitoring: Stay connected and keep track of temperature and humidity from anywhere by simply using your smartphone and the Tuya Smart or Smart Life app. Whether you're at home or away, conveniently monitor the conditions of your environment by the temperature humidity sensor.
2. Temperature Unit Customization: Tailor the temperature display of the accurate hygrometer temp meter to your preference by selecting between Celsius (℃) or Fahrenheit (℉) within the app. Choose the unit that you're most familiar with for easy understanding.
3. Voice Control Compatibility: Experience hands-free convenience with our hygrometer thermometer detector that is suitable for popular voice assistants like for Amazon Alexa and for Google Assistant. Use simple voice commands to view the current temperature and humidity without having to lift a finger.
4. Long-lasting Battery: Our hygrometer temperature gauge is designed with energy efficiency in mind, ensuring a longer battery life. It operates on two AAA batteries (not included), allowing for prolonged use while being eco-friendly and durable.
5. Clear LCD Display: The room thermometer hygrometer features an LCD screen that provides a clear and easily readable display of the current temperature and humidity readings. Get instant access to accurate information at a glance, making it effortless to stay informed about your surroundings.
Specification:
Smart home platform: Alexa,Google Assistant
Certification: NONE
Origin: Mainland China
Model Number: Temperature Sensor
Battery: AAA*2 (not included)
Operating Temperature: -9.9℃ to 60℃
Wireless Protocol: 2.4Ghz Wifi Zigbee 3.0
Operating Humidity: 5%RH to 95%RH
Temperature Accuracy: ±1℃
Humidity Accuracy: ±5%RH
Casing Material: ABS
Product Dimensions: About 51.00x51.00x16.50mm (2.01x2.01x0.65in)
Type(optional): Wifi Version/Zigbee Version
Note:
1. Due to the different monitor and light effect, the actual color of the item might be slightly different from the color showed on the pictures. Thank you!
2. Please allow 1-2cm measuring deviation due to manual measurement.
Feature:
Specification:
Certification: NONE
Note:
1 x Temperature Humidity Sensor
