Shop EISsound In-Wall Bluetooth Audio Receiver with Power Supply (White Color)
Enhance your audio experience with the EISsound In-Wall Bluetooth Audio Receiver with Power Supply in White (U.S.). This sleek and compact device allows you to stream high-quality audio wirelessly from your Bluetooth-enabled devices, such as smartphones, tablets, or laptops, directly to your in-wall speakers.
Features and Benefits:
Seamless Integration: Designed to fit seamlessly into your wall, the in-wall Bluetooth audio receiver ensures a clean and clutter-free space.
Wireless Streaming: Enjoy high-quality audio streaming from any Bluetooth-enabled device, providing you with the convenience of wireless connectivity.
Included Power Supply: The Bluetooth audio receiver with power supply ensures your receiver is always ready to use, offering consistent and reliable performance.
Easy Installation: With an easy installation process, you can quickly set up your bluetooth audio receiver and start enjoying your favorite music, podcasts, and more.
Versatile Use: Ideal for both home and commercial spaces, the in-wall Bluetooth audio receiver is a must-have for enhancing any audio setup.
Clutter-Free Design: The in-wall installation provides a sleek, unobtrusive look, maintaining the aesthetic of your space.
Enhanced Audio Experience: Stream music wirelessly with high-quality sound, transforming your audio experience at home or in commercial environments.
Reliability and Convenience: With a consistent power supply and easy-to-use design, this Bluetooth audio receiver offers hassle-free functionality.
Color: White (U.S. version)
Compatibility: Works with all Bluetooth-enabled devices
Power Supply: Included
Installation: Fits seamlessly into standard in-wall outlets
Upgrade your audio setup with the EISsound In-Wall Bluetooth Audio Receiver with Power Supply. Enjoy the convenience of wireless streaming and the elegance of a clutter-free design.
Product Specs:
Manufacturer Part #:
52807
UPC:
8436031618655
Outputs:
Stereo Line Right Speaker Left Speaker Amplifier Trigger
Speaker Impedance:
4/8/16 ohms
Speaker Output:
5W stereo max.
Other Connection:
Volume limitation and mono/stereo jumpers
LED Display:
Off: Disconnected and Audio Off
Bluetooth:
Blue Flashing – searching BT Device
Bluetooth:
Blue On – BT connected
Audio-In:
Red On – Audio-In Activated
Voltage Terminals VDC, GND:
Normal: 15Vdc Max: 16Vdc
Consumption Demand Bluetooth Operation:
Minimum: 22mA Normal: 111mA
Consumption Demand Jack 3.5mm:
Minimum: 22mA Normal: 99mA
Input Signal Jack 3.5mm:
Normal: 100mVrms Maximum: 550mVrms
Input Impedance Jack 3.5mm:
Minimum: 7Kohms Maximum: 60Kohms
Output Signal Output 4 ohm:
Maximum: 5Wrms
Output Signal Output 8 ohm:
Maximum: 2.5Wrms
Output Signal Output 16 ohm:
Maximum: 1.5Wrms
Line Output Signal Terminals 65, 66, 4:
Maximum: 1.82Vrms
Line Output Signal Terminals 65, 66, 4 Output Impedance:
Maximum: 50ohm
Amplifier Trigger Signal Terminals 62, 4:
Maximum: 14Vdc
Amplifier Trigger Signal Terminals 62, 4 Output Impedance:
