Enbrighten Zigbee 3.0 In-Wall Smart Dimmer, Paddle, No Energy, xref 45857GE
Regular price $64.95
Regular price $64.95 Sale price
Shop Enbrighten Zigbee 3.0 In-Wall Smart Dimmer, Paddle, No Energy, xref 45857GE
Transform your living space with the Enbrighten Zigbee 3.0 In-Wall Smart Dimmer, a cutting-edge solution designed to bring convenience and efficiency to your home. With this Zigbee 3.0 In-Wall Smart Dimmer, you can effortlessly control the brightness of your lights from anywhere using your smartphone or voice commands, integrating seamlessly with popular smart home systems.
Seamless Smart Home Integration
The Enbrighten Zigbee In-Wall Smart Dimmer is fully compatible with Zigbee 3.0 technology, ensuring robust connectivity and quick response times. It integrates smoothly with your existing smart home ecosystem, allowing you to control your lighting through platforms like Amazon Alexa, Google Assistant, and more. The xref 45857GE model provides hassle-free pairing, making it easy to upgrade your home with intelligent lighting controls.
User-Friendly Paddle Design
Featuring a sleek paddle design, this In-Wall Smart Dimmer offers intuitive control over your lighting. With a simple tap, you can adjust the brightness levels to create the perfect ambiance for any occasion. Whether you’re dimming the lights for a cozy movie night or brightening up a room for work, this smart dimmer makes it easy and convenient.
Energy Efficiency at Its Best
Not only does the Zigbee 3.0 In-Wall Smart Dimmer enhance your home's lighting, but it also helps you save on energy costs. The dimmer is engineered for efficiency, reducing energy consumption by adjusting light output to your needs. Enjoy the benefits of smart lighting while also lowering your electricity bills.
  • Zigbee 3.0 Compatibility: Seamless integration with your smart home system for remote and voice control.
  • Paddle Design: Easy-to-use interface for smooth dimming and light adjustments.
  • Energy-Efficient: Optimizes energy usage, helping you save on electricity.
  • Smart Home Integration: Works with popular platforms like Amazon Alexa and Google Assistant.
  • Effortless Installation: Fits standard wall boxes and requires no additional wiring, making it a straightforward upgrade for your home.
Product Specs:
Manufacturer Part # 43080
UPC 030878430807
Color White and Light Almond paddles included
Power 120 VAC, 60 Hz
Frequency 2.4Ghz IEEE 802.15.4
Max Load Ratings 1-Gang: 600W
2-Gang: 500W
3-Gang: 400W incandescent; 300W CFL/LED
Range Up to 150 feet line of sight between the Wireless Controller and the closest Zigbee receiver module.
Environmental Conditions For indoor use only.
Operating Temperature Range 32 to 104°F (0 to 40°C)
Approvals FCC, IC
Warranty 2 Year Limited
Why Choose the Enbrighten Zigbee In-Wall Smart Dimmer?
The Enbrighten Zigbee 3.0 In-Wall Smart Dimmer is an excellent choice for homeowners looking to enhance their lighting with smart technology. It offers a blend of convenience, style, and energy efficiency, all while integrating smoothly into your existing smart home setup. Upgrade to the Enbrighten Zigbee In-Wall Smart Dimmer today and take control of your lighting like never before.
Shop Enbrighten Zigbee 3.0 In-Wall Ezlo
