EU US LCD Smart Wifi Water Heater Boiler Switch 16A Work with Apple Homekit Alexa Google Home Switch for Smart Home 110V 220V
Hign-concerned Chemical: None
Communication method: Wi-Fi
Camera Equipped: No
State of Assembly: Ready-to-Go
Model Number: LANBON
- Hign-concerned Chemical: None
- Communication method: Wi-Fi
- Camera Equipped: No
- State of Assembly: Ready-to-Go
- Model Number: LANBON
- Compatibility: IOS
- Brand Name: weten
- Origin: Mainland China
- Certification: CE,FCC
- Current: 16A
- Voltage: 100V-250V
- Wifi Standard: 2.4GHz, 802.11 b/g/n
- Warranty: 1 Year
LCD Touch Screen
The Smart Boiler Switch has LCD touch screen functionality to show more information and allow customisation. You can customise the switch icon, name, and overall theme to your preference.
NO Hub Required
This switch can be connected with wifi router direcely, not need hub/gateway/Bridge.
2 Wire Cut off
When turn off the switch, both the neutral wire and live wire will be cut off, much more safe.
Quick timmer setting
One key to set timmer by 30/60 min, also support custom setting. easy and convenient.
App Control
Anytime anywhere, control the Smart Light Switch through Apple Homekit App
Voice Control
Control the Smart Light Switch through your voice with Google Home, Alexa Echo and Siri.
Delay & Timmer function
Set a delay to turn Boiler on/off after a specified time. Schedule Boiler to turn on/off during your preferred time of day.
Vertical or Horizontal installation
You can choose the screen to display in vertical or horizontal according to personal preference.
Standby Mode & Night Mode
To save energy, the switch turns to standby mode automatically with the screen light dimmed to the setting level. In the mode, the LED backlight around the frame will be turned off.
Attention
1. Neutral wire is requird for this switch, pls make sure your house has neutral wire.
2. This switch is only for Apple iphone or ipad, support Apple Homekit App and Siri Voice Control.
3. This switch isn't compatiable with Android phone, don't support HOME ASSISTANT.
>>> If you need Android Version or Home Assistant Compatiable Version, pls contact us <<<
