Ewelink E26 E27 Zigbee LED Bulbs Wifi Smart LED Lamp RGB+CW+WW 15W 18W LED Light Bulb Works With Alexa Google Smartthings Yandex
  • Luminous Flux: 249-2000
  • Power Source: AC
  • Hign-concerned Chemical: None
  • Warranty: 3years
  • Area: 3-8㎡
  • Power Source: AC
  • Warranty: 3years
  • Area: 3-8㎡
  • Is Smart Device: YES
  • Model Number: Smart E27 LED light bulbs
  • Luminous Flux: 500 - 999 Lumens
  • Color Temperature: 2700K~6500K
  • Voltage: AC100-240V
  • Occasion: LIVING ROOM
  • Power Tolerance: 5%
  • LED Chip Brand: Epistar
  • Shape: Globe
  • Beam Angle(°): 120°
  • Base Type: E26
  • Length: 0.12m
  • Origin: Mainland China
  • Item Type: LED bulbs
  • Brand Name: coolo
  • Led Bulb Type: Bubble Ball Bulb
  • Certification: ce,FCC,ROHS
  • Average Life (hrs): 30000
  • LED Chip Model: 2835
Type: Zigbee / WiFi Smart LED Bulb
Material: Aviation Aluminum, plastic
Socket Type: E27
Power: RGB+CW+WW 15W/18W
Voltage: AC 100V~240V
Life: >30000h
APP Download: eWelink
Network: 2.4GHz Wi-Fi/Zigbee 3.0(need Zigbee Hub Gateway)
Light color: RGB + Warm white + White (3000K-6000K)
Function: Voice Control, APP Remote Control, Dimmable, compatible with Amazon Alexa Echo Google Home Assistant.
Zigbee Hub As Control Central: Zigbee Gateway Hub is Required for Zigbee bulb, performing as the center bridge for all zigbee device with extremely stable signal and a really good necessity for whole-house intelligence.
Note: If you don't have zigbee hub gateway, just buy WiFi type.
