$ 72.00 $ 57.60 -20%
Hide it behind the wall, tuck it inside the fixture, drop it in line with any 120V circuit. The Ezlo Z-Wave In-Line Switch turns ordinary devices into connected ones — with energy monitoring, local control, and a 1500W max load. Powered by the universal Z-Wave 800 series, it delivers exceptional range and connection stability — works seamlessly into your existing setup for a hassle-free smart home upgrade.
15A MAX
500mm (L) × 65mm (W) × 27mm (H)
AC 120V, 60Hz
Up to 328 ft outdoors, ~131 ft indoors (depending on building materials)
≤1.5W
912.00 MHz (default), 920.00 MHz (backup)
1800W
−14°F ~ 104°F
Z-Wave Plus
908.40 MHz, 908.42 MHz, 916.00 MHz
High Voltage Device: Risk of Electric Shock This device operates on AC 100-240V electricity. Installation requires direct interaction with your home's electrical wiring.
Heavy Duty Capable: Unlike standard smart plugs, this switch supports up to 15A, making it suitable for larger lighting fixtures or appliances.
Do Not Overload: Ensure your connected device does not exceed 1800W to prevent damage or safety hazards.
Upgrade your existing lights and appliances into a connected, energy-aware home — no rewiring, no replacements, no compromise
Full Control
Turn anything on, off, or on a schedule from your phone — even fixtures you've had for years
Real-Time Energy Monitoring
Track every watt. Find out what's costing you and where you can save
Built to Perform
Z-Wave 800 series for extended range and a connection that holds, even at the edges of your network
Drop-In Upgrade
Install in line with what's already there. No new switches, no new fixtures, no electrician on standby
Upgrade your home in minutes. The Ezlo In-Line Switch slips behind the wall or inside the fixture and brings any 120V circuit onto your smart home — lights, fans, pumps, appliances, even the things you forgot weren't smart yet. With the latest Z-Wave 800 series technology, you get the fastest, most reliable connection available — simple, efficient, and effortless.
Energy Reporting
See your usage in real time. Spot what's costing you, set goals, and take action
Voice Activation
Compatible with Amazon Alexa and Google Assistant, allowing for hands-free control of associated devices
Home Assistant Ready:
Plug-and-play with your existing Home Assistant setup — no extra integrations, no custom code
LED Indicators
RGB LED shows Z-Wave network range and load-power status at a glance
Remote & Manual Control
Switch the AC output on or off via your hub's app or Home Assistant or by using the power button on the smart switch
US-Based Customer Care:
Enjoy peace of mind with US-based, real-person customer support ready to assist you whenever you need help
The Ezlo Z-Wave In-Line Switch tucks behind the wall or inside the fixture — turning any 120V circuit into a smart one without replacing a thing
Hidden InstallSits in line with what's already there. No new switches, no new fixtures, no rewiring — just smarter
Real-Time Energy MonitoringTrack live wattage and accumulated kWh from the app. Spot energy-hungry circuits and start cutting your utility bills from day one
Superior Z-Wave 800 RangeBuilt on the latest Z-Wave 800 series technology for the fastest, most reliable connection — reaching over 328 ft outdoors and strengthening your entire Z-Wave mesh network
Supports power meter functionality to monitor and report wattage consumption and kWh energy usage.
Switch the AC output on or off via MiOS app or by using the manual Z-Wave Pairing button.
Utilizes the Z-Wave 800 series for advanced, long-range connectivity.
Real-time control and monitoring, right from your phone
With the MiOS app, you can see exactly how much power any wired-in device is drawing — live wattage, accumulated energy, voltage — all from your chair. Set automations to turn devices off on a schedule, get alerts when something's been left on, or simply switch it off remotely. The Ezlo Z-Wave In-Line Switch puts your energy data where it belongs: in your hands
A: Yes. This is a Z-Wave 800 Series device and requires a Z-Wave compatible controller (like an Ezlo hub) to receive commands, manage automations, and update firmware
A: Yes. The Ezlo In-Line Switch is compatible with most 3rd-party Z-Wave hubs. It uses standard Z-Wave Plus protocols, allowing it to integrate seamlessly into networks managed by SmartThings, Hubitat, Home Assistant, and other major Z-Wave controllers
A: Capacity and Form Factor. The In-Line Switch supports a higher load (15A vs 10A) and is designed to be installed "in-line" with your device's power cord. It is ideal for controlling devices where a bulky wall plug might not fit or for retrofitting extension cords
A: Yes. It features comprehensive Energy Reporting. The switch reports real-time wattage consumption and accumulated kWh energy usage back to your hub, helping you track the cost of running specific devices
A: Excellent. Built with Z-Wave 800 Series technology, it supports long-range connectivity, reaching more than 328 ft outdoors and approximately 131 ft indoors (depending on building materials)
A: Yes. The switch is "Home Assistant Ready." It works perfectly for simple on/off control or deep-dive automations within Home Assistant and other open Z-Wave environments
A: Yes. It features a manual Z-Wave Pairing Button on the unit itself, allowing you to toggle the power on or off physically without using the app
A: We are here to help! For installation questions or troubleshooting, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com
