Ezlo Z-Wave In-Line Switch 3 Pack
$ 102.40 $ 81.92 -20%
Hide it behind the wall, tuck it inside the fixture, drop it in line with any 120V circuit. The Ezlo Z-Wave In-Line Switch turns ordinary devices into connected ones — with energy monitoring, local control, and a 1500W max load. Powered by the universal Z-Wave 800 series, it delivers exceptional range and connection stability — works seamlessly into your existing setup for a hassle-free smart home upgrade.
1 Year Manufacturer Warranty
Free Shipping on orders over $49.99
Free Returns for 30 Days
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub The Ezlo Plus hub offers extensive control and compatibility with thousands of Z-Wave and Zigbee devices, including Centralite’s sensor lineup. With MiOS automation, it functions as a powerful, self-monitored safety system—delivering real-time ale...
$ 149.95
1
Hidden install — sits in-line, behind the wall or inside the fixture
1500W max load — powerful enough for lights, fans, and most appliances
Energy monitoring — see exactly what every connected circuit is drawing
Local + cloud — runs on your network first, cloud second
Universal Z-Wave — works with hundreds of certified hubs and devices
Pairs with MiOS — full automation through MiOS and Ezlo Plus
Rated Load Current:
15A MAX
Dimensions:
500mm (L) × 65mm (W) × 27mm (H)
Power Supply:
AC 120V, 60Hz
Range:
Up to 328 ft outdoors, ~131 ft indoors (depending on building materials)
Power Consumption:
≤1.5W
Z-Wave LR Radio Frequency:
912.00 MHz (default), 920.00 MHz (backup)
Power Output (resistive load):
1800W
Operational Temperature:
−14°F ~ 104°F
Radio protocol:
Z-Wave Plus
Z-Wave Radio Frequency (US):
908.40 MHz, 908.42 MHz, 916.00 MHz
FCC CE RoHS WEEE
Specifications
High Voltage Device: Risk of Electric Shock This device operates on AC 100-240V electricity. Installation requires direct interaction with your home's electrical wiring.
Heavy Duty Capable: Unlike standard smart plugs, this switch supports up to 15A, making it suitable for larger lighting fixtures or appliances.
Do Not Overload: Ensure your connected device does not exceed 1800W to prevent damage or safety hazards.
Reliable Smart Control
& Energy Insights
Upgrade your existing lights and appliances into a connected, energy-aware home — no rewiring, no replacements, no compromise
Full Control
Turn anything on, off, or on a schedule from your phone — even fixtures you've had for years
Real-Time Energy Monitoring
Track every watt. Find out what's costing you and where you can save
Built to Perform
Z-Wave 800 series for extended range and a connection that holds, even at the edges of your network
Drop-In Upgrade
Install in line with what's already there. No new switches, no new fixtures, no electrician on standby
Make Any Device Smart with Ezlo
Upgrade your home in minutes. The Ezlo In-Line Switch slips behind the wall or inside the fixture and brings any 120V circuit onto your smart home — lights, fans, pumps, appliances, even the things you forgot weren't smart yet. With the latest Z-Wave 800 series technology, you get the fastest, most reliable connection available — simple, efficient, and effortless.
Energy Reporting
See your usage in real time. Spot what's costing you, set goals, and take action
Voice Activation
Compatible with Amazon Alexa and Google Assistant, allowing for hands-free control of associated devices
Home Assistant Ready:
Plug-and-play with your existing Home Assistant setup — no extra integrations, no custom code
LED Indicators
RGB LED shows Z-Wave network range and load-power status at a glance
Remote & Manual Control
Switch the AC output on or off via your hub's app or Home Assistant or by using the power button on the smart switch
US-Based Customer Care:
Enjoy peace of mind with US-based, real-person customer support ready to assist you whenever you need help
Smarter Control, Hidden Install
The Ezlo Z-Wave In-Line Switch tucks behind the wall or inside the fixture — turning any 120V circuit into a smart one without replacing a thing
Hidden InstallSits in line with what's already there. No new switches, no new fixtures, no rewiring — just smarter
Real-Time Energy MonitoringTrack live wattage and accumulated kWh from the app. Spot energy-hungry circuits and start cutting your utility bills from day one
Superior Z-Wave 800 RangeBuilt on the latest Z-Wave 800 series technology for the fastest, most reliable connection — reaching over 328 ft outdoors and strengthening your entire Z-Wave mesh network
Power Metering Power Metering
Power Metering
Remote & Manual Control Remote & Manual Control
Z-Wave 800 Series Z-Wave 800 Series
Z-Wave 800 Series
Power Metering
Power Metering
Supports power meter functionality to monitor and report wattage consumption and kWh energy usage.
Switch the AC output on or off via MiOS app or by using the manual Z-Wave Pairing button.
Z-Wave 800 Series
Z-Wave 800 Series
Utilizes the Z-Wave 800 series for advanced, long-range connectivity.
Your Home's Energy, At a Glance
Real-time control and monitoring, right from your phone
With the MiOS app, you can see exactly how much power any wired-in device is drawing — live wattage, accumulated energy, voltage — all from your chair. Set automations to turn devices off on a schedule, get alerts when something's been left on, or simply switch it off remotely. The Ezlo Z-Wave In-Line Switch puts your energy data where it belongs: in your hands
Frequently Asked Questions
Q: Do I need a hub to use this switch?
A: Yes. This is a Z-Wave 800 Series device and requires a Z-Wave compatible controller (like an Ezlo hub) to receive commands, manage automations, and update firmware
Q: Will this work with my existing Z-Wave hub?
A: Yes. The Ezlo In-Line Switch is compatible with most 3rd-party Z-Wave hubs. It uses standard Z-Wave Plus protocols, allowing it to integrate seamlessly into networks managed by SmartThings, Hubitat, Home Assistant, and other major Z-Wave controllers
Q: What is the difference between this and the Smart Plug?
A: Capacity and Form Factor. The In-Line Switch supports a higher load (15A vs 10A) and is designed to be installed "in-line" with your device's power cord. It is ideal for controlling devices where a bulky wall plug might not fit or for retrofitting extension cords
Q: Does it monitor energy usage?
A: Yes. It features comprehensive Energy Reporting. The switch reports real-time wattage consumption and accumulated kWh energy usage back to your hub, helping you track the cost of running specific devices
Q: How is the wireless range?
A: Excellent. Built with Z-Wave 800 Series technology, it supports long-range connectivity, reaching more than 328 ft outdoors and approximately 131 ft indoors (depending on building materials)
Q: Does it work with Home Assistant?
A: Yes. The switch is "Home Assistant Ready." It works perfectly for simple on/off control or deep-dive automations within Home Assistant and other open Z-Wave environments
Q: Can I control it manually?
A: Yes. It features a manual Z-Wave Pairing Button on the unit itself, allowing you to toggle the power on or off physically without using the app
A: We are here to help! For installation questions or troubleshooting, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com
Download on App Store App Store QR
Get it on Google Play Google Play QR
Frequently Bought Together
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 149.95
Shop now
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now
Ezlo Smart Doorbell Camera
$ 179.97
Shop now
Trusted Around the World
What's New at Ezlo
