GE Jasco Plug-In Smart Dimmer
Transform your home into a smart home using the plug-in ZigBee Smart Dimmer from GE. This unique Smart Dimmer allows you to remotely turn on or off any table or floor lamp, while also controlling the lamp's brightness level, using your existing Vera controller and does not require wiring. The ZigBee Smart Dimmer includes one controlled outlet and one always-on, standard outlet, and it's space-saving, horizontal design plugs into standard receptacles without blocking the second outlet. The Smart Dimmer can be used with any standard incandescent bulb as well as dimmable CFL and LED bulbs. Take control of your home lighting with GE ZigBee Wireless Lighting Controls!
