GoControl 3-Way Switch Light
Regular price $39.95
Regular price $39.95 Sale price
Simplify Multi-Switch Lighting Control with the GoControl 3-Way Light Switch
The GoControl 3-Way Switch Light allows remote ON/OFF control and dimming of lights controlled by associated Z-Wave modules, creating virtual 3-way switches Ezlo controller. The Three-Way Light Switches Control not load directly, so it can be wired anywhere power is available, without the need for a traveler wire. This ingenious device works seamlessly with your existing wiring to create a virtual 3-way switch, granting you remote control and dimming capabilities for your lights from anywhere in your home using a compatible Z-Wave hub (hub sold separately).
  • Remote Control and Dimming: The 3-Way Light Switch provides convenient ON/OFF control and dimming of your lights via Z-Wave modules, giving you full control over your home lighting from anywhere using the Ezlo controller.
  • Flexible Installation: Unlike traditional switches, the 3-Way Switch Light does not directly control the load, which means it can be installed wherever power is available, eliminating the need for a traveler wire. This makes it a perfect solution for retrofitting existing wiring setups.
  • Seamless Integration: The GoControl light switch is designed to integrate effortlessly with your existing Z-Wave network, ensuring smooth communication and reliable performance.
  • Enhanced Convenience: Enjoy the convenience of controlling and dimming your lights remotely, enhancing the comfort and ambiance of your home.
  • Simplified Wiring: The ability to install the 3-Way Switch Light anywhere power is available simplifies the installation process and reduces the need for extensive rewiring.
  • Smart Home Compatibility: Compatible with various Z-Wave modules, the GoControl light switch can be easily incorporated into your smart home ecosystem, providing seamless automation and control.
