Home Assistant Smart Water Leakage Sensor Detector Wireless Zigbee Leak for Basement Kitchen Home Security Ewelink
$12.01
Lincukoo Home Assistant Smart Water Leakage Sensor Detector Wireless ZigBee Leak For Basement Kitchen Home Security eWeLink
Important Note:
The zigbee version only be used on eWeLink or Home Assistant platform, need gateway to use :
a).Go to the link to buy
b).Go to the link to buy
Tip: In order to save your usage costs, this product is shipped with a battery included
Water Leakage Alarm Sensor Description:
-Detect water leakage real time and sound alarm: This product can sound alarm(>80db) to indicate the leakage point as soon as water leakage detected, and send notification to your mobile phone when connect to internet, can also linkage with other devices to build up smart application scene, for instance, close the water valve in case of kitchen sink leaks
-Its height is only 14mm,so can be placed into narrow spaces, such as under the washing machine, sink, washbasin, refrigerator……, ensuring prompt action to safeguard your home.
-High-capacity batteries can be used for 2yeas at least (the duration may vary depending on the usage environment), even if low battery alarm, still can last for 1-2months.
-Tool-free Installation
You don't need any complicated wiring or tools. Just put it to the place where you want to detect the water leakage.
