INKBIRD ITC-306T-WIFI Heating and Cooling Dual Relay Temperature Controller for Greenhouse ,Propagation,Cultivation,Brewing
Dual Relay Design: The controller is equipped with two relays, allowing independent control of heating and cooling devices. This ensures accurate temperature regulatio..
The INKBIRD ITC-306T-WIFI is a versatile WIFI Temperature Controller designed to provide precise and reliable temperature management for various applications, including Greenhouse Temperature Control, propagation, cultivation, and brewing. This Dual Relay Temperature Controller offers both heating and cooling functions, ensuring optimal environmental conditions for your projects.
Dual Relay Design: The controller is equipped with two relays, allowing independent control of heating and cooling devices. This ensures accurate temperature regulation, essential for applications like Greenhouse Temperature Control.
Wi-Fi Connectivity: With 2.4GHz Wi-Fi support, you can remotely monitor and adjust temperature settings via the INKBIRD app, providing convenience and flexibility in managing your environment.
Day and Night Temperature Settings: Customize separate temperature settings for day and night cycles to cater to the specific needs of plants and animals, enhancing growth and health.
High and Low Temperature Alarms: Set alarms to notify you when temperatures deviate from the desired range, ensuring prompt action to maintain optimal conditions.
- Dual Display Screen: The device features a dual-screen display, simultaneously showing the current temperature and set temperature for easy monitoring.
The INKBIRD ITC-306T-WIFI WIFI Temperature Controller is ideal for applications requiring precise temperature management, such as:
Greenhouse Temperature Control: Maintain optimal temperatures for plant growth by managing heating and cooling systems effectively.
Propagation and Cultivation: Ensure consistent temperatures for seed germination and plant development, leading to healthier yields.
- Brewing: Achieve accurate temperature control during fermentation processes, resulting in better-quality brews.
By utilizing this Dual Relay Temperature Controller, users can create stable environments tailored to their specific needs, leading to improved outcomes in various applications.
