INKBIRD WiFi Thermometer Hygrometer Indoor Digital Temperature Humidity Smart Sensor IBS-TH3-PLUS For Home Weather Station
  • WiFi Connectivity: The INKBIRD WiFi Thermometer connects seamlessly to your 2.4GHz WiFi network, allowing you to monitor real-time temperature and humidity data remote..
The INKBIRD IBS-TH3-PLUS is a smart indoor thermometer and hygrometer designed to provide precise monitoring of temperature and humidity levels in your home. Equipped with a high-precision Swiss-made sensor, it ensures accurate measurements with a temperature accuracy of ±0.3℃ (±0.5℉) and a humidity accuracy of ±3%RH.
  • WiFi Connectivity: The INKBIRD WiFi Thermometer connects seamlessly to your 2.4GHz WiFi network, allowing you to monitor real-time temperature and humidity data remotely via the INKBIRD app on your smartphone.
  • Smart Alerts: Set customizable high and low thresholds for temperature and humidity. Receive instant notifications on your device when these limits are exceeded, ensuring you can take timely action to maintain a comfortable environment.
  • Long Battery Life: Featuring a built-in 500mAh USB rechargeable battery, the INKBIRD Hygrometer Smart Sensor can operate for up to six months on a single charge under standard conditions, reducing the need for frequent battery replacements.
  • Data Storage and Export: The device stores up to one year of historical temperature and humidity data, accessible through the app. You can export this data in CSV format for detailed analysis and record-keeping.
  • User-Friendly Display: The large LCD screen displays current temperature and humidity readings alongside comfort level emoticons, providing an intuitive understanding of your indoor environment at a glance.
The INKBIRD IBS-TH3-PLUS is ideal for various indoor settings, including homes, offices, greenhouses, wine cellars, and baby rooms. By providing accurate and real-time monitoring, it helps you maintain optimal temperature and humidity levels, ensuring comfort and preventing potential issues related to improper environmental conditions. Its remote monitoring capabilities and smart alerts offer peace of mind, knowing you can oversee your environment from anywhere.
