Leviton Decora Smart Z-Wave Plug-In Appliance Module
$43.95
Incandescent: 1800W – 120VAC, 60 Hz
LED/CFL: 5A – 120VAC, 60Hz
Fluorescent: 1800W – 120VAC, 60 Hz
Resistive: 15A – 120VAC, 60Hz
Motor: 1/2 HP – 120VAC, 60Hz
The Leviton Decora Smart Z-Wave Plug-In Appliance Module is a versatile and user-friendly device that allows you to control your home appliances from anywhere. This plug-in module can be easily installed into any standard outlet, giving you the ability to remotely turn on and off any device that is plugged into it.
With Z-Wave technology, this appliance module can be integrated with your existing smart home system, allowing you to control it using voice commands or through a mobile app. You can also set schedules and timers for your appliances, which can help you save energy and automate your daily routines.
This appliance module is designed with safety in mind, featuring a built-in surge protector that helps prevent damage to your devices during power surges. It is also UL-listed for quality and safety assurance.
The Leviton Decora Smart Z-Wave Plug-In Appliance Module is compatible with a wide range of appliances, including lamps, fans, heaters, and more. It is a must-have device for anyone looking to simplify their home automation setup and increase their control over their appliances. The specification of Leviton Decora Smart Z-wave is below.
Package Includes
Wall Plate not included
| Manufacturer Part #: | DZPA1-2BW |
| Ratings: |
| Agency Standing and Compliance: | Complies with FCC Part 15, Class B UL Listed (E66800) NOM Certified (#057) CSA Certified (File #152105) UL Listed (File #898F) Z-Wave Certified |
| Installation Considerations: | Designed for residential applications of up to 7,500 sq. ft. |
| Warranty: | 5 Year Limited |
