Leviton Decora Smart Z-Wave Plug-In Dimmable Lamp Module
$43.95
The Leviton Decora Smart Z-Wave Plug-In Dimmable Lamp Module is a powerful and versatile device that allows you to control your lighting with ease. This plug-in module is designed to work with Z-Wave technology, which means it can be controlled using a variety of different devices, including smartphones, tablets, and smart home hubs.
With the Leviton Decora Smart Z-Wave Plug-In Dimmable Lamp Module, you can easily adjust your lighting to create the perfect ambiance in any room. The module supports dimming, so you can set the level of brightness to your liking. Plus, it's easy to install - simply plug it into any standard outlet and you're ready to go.
This lamp module is compatible with a wide range of different light bulbs, including LED, incandescent, and CFL bulbs. It also features a convenient on/off switch, so you can easily turn your lights on or off with just a touch.
Whether you're looking to create a cozy atmosphere in your living room, or you want to set the mood for a romantic dinner, the Leviton Decora Smart Z-Wave Plug-In Dimmable Lamp Module is the perfect solution. With its easy installation, versatile compatibility, and intuitive controls, this module is a must-have for anyone who wants to take control of their lighting.
Package Includes
Wall Plate not included
| Manufacturer: | Leviton |
| Part Number: | DZPD3-2BW |
| Item Weight: | 4.6 ounces |
| Product Dimensions: | 2.2 x 2 x 3 inches |
| Country of Origin: | China |
| Item Model Number: | DZPD3-2BW |
| Is Discontinued By Manufacturer: | No |
| Size: | 1 Pack |
| Color: | White |
| Style: | Plug-in Dimmer |
| Material: | Smart |
| Pattern: | Dimmer |
| Thickness: | 1 Inch |
| Wattage: | 300 watts |
| Item Package Quantity: | 1 |
| Number Of Holes: | 300 |
| Switch Type: | 2-way |
| Mounting Type: | Plug-In Mount |
| Switch Style: | Dimmer Switch |
| Certification: | NEMA |
| Included Components: | Device |
| Batteries Included: | No |
| Batteries Required: | No |
| Warranty Description: | Limited 5-Year |
