GoControl Plug-In Dimmer
Regular price $29.95
Regular price $29.95 Sale price
Low stock
Shop GoControl Plug-In Dimmer at Best Price
The GoControl Plug-In Dimmer is the perfect solution for adding Z-Wave control to your dimmable lamps. This versatile device plugs into any standard grounded AC wall outlet, and your lamp is then plugged into the module, allowing you to dim, turn on, or turn off your lamp remotely via your Vera Home Controller.
With the gocontrol z wave plug in dimmer, you get the convenience of two power receptacles: one controlled and one pass-through (always powered), making it ideal for any setup. Its excellent compatibility with Vera ensures seamless integration into your existing smart home system.
Key Features:
  • Easily dim, turn on, or off your lamp remotely via the Vera Home Controller.
  • One controlled outlet and one pass-through outlet for added convenience.
  • Plug into any standard grounded AC wall outlet and connect your lamp.
  • Works seamlessly with Vera for a unified smart home experience.
Upgrade your home lighting with the GoControl Plug-In Dimmer and enjoy the convenience of smart lighting control.
GoControl Plug-In Dimmer - Vera Shop
