Matter WiFi Smart Switch Neutral Wire/No Neutral Wire 1/2/3 Gang Touch Wall Light Switch Work with Homekit Alexa Google Home
  • Versatile Wiring Compatibility: Designed to work with both neutral and no-neutral wire setups, this switch offers flexibility for various home electrical systems
  • Touch Control: The sleek touch-sensitive interface allows for intuitive operation, enhancing the modern aesthetic of your living spaces
  • Voice and App Control: Easily control your devices using voice commands through Alexa, Siri, Google Assistant, or any other Matter-certified device, allowing for hands..
  • Multiple Gang Options: Available in 1, 2, or 3-gang configurations, it caters to different control needs within your home
Shop Matter WiFi Smart Switch 1/2/3 Gang Touch Wall Light Switch Smart Dimmer Switch
Introducing the Matter WiFi Smart Switch, a cutting-edge solution designed to elevate your home automation experience. This versatile switch is compatible with both neutral and no-neutral wire configurations, making it suitable for various home wiring systems. Available in 1, 2, or 3-gang touch wall designs, it seamlessly integrates with major platforms like HomeKit, Alexa, and Google Home, offering unparalleled convenience and control.
The Matter WiFi Smart Switch is engineered to provide seamless smart home integration, adhering to the Matter standard protocol and certified by the Connectivity Standards Alliance (CSA). This certification ensures broad compatibility across a wide range of smart home devices and platforms, providing you with peace of mind.
  • Versatile Wiring Compatibility: Designed to work with both neutral and no-neutral wire setups, this switch offers flexibility for various home electrical systems.
  • Touch Control: The sleek touch-sensitive interface allows for intuitive operation, enhancing the modern aesthetic of your living spaces.
  • Voice and App Control: Easily control your devices using voice commands through Alexa, Siri, Google Assistant, or any other Matter-certified device, allowing for hands-free convenience. Additionally, manage your smart switch through apps like the Alexa App, Apple Home, Google Home, and SmartThings, making it simple to customize your home automation experience.
  • Multiple Gang Options: Available in 1, 2, or 3-gang configurations, it caters to different control needs within your home.
The Matter WiFi Smart Switch enhances your home lighting system by providing remote access, scheduling, and automation capabilities. Whether you're at home or away, you can monitor and control your lighting, contributing to energy efficiency and added security. Its compatibility with major smart home platforms ensures that it integrates smoothly into your existing ecosystem.
For homes with existing neutral wiring, the Neutral Smart Switch configuration offers optimal performance, especially with LED lighting systems. It provides better dimming capabilities and reduces the risk of flickering or "ghosting" effects
For those looking to adjust lighting intensity, the smart dimmer switch feature allows for precise control over brightness levels, creating the perfect ambiance for any occasion.
Additional Specifications
  • Rated Power: AC 100-240V, 50/60Hz
  • Rated Current: 10A
  • Operation Range: Up to 30 meters
  • Wi-Fi Type: 2.4GHz
  • Operation Temperature: -10~40℃
Elevate your home's lighting control with the Matter WiFi Smart Switch, and experience the convenience and efficiency of modern smart home technology.
