Meian Zigbee Window Door Sensor Tuya Smart Home Wireless Door Alarm Wifi Door Sensor Open Closed Detector Security Protection
Meian Tuya Zigbee3.0 Window Door Sensor Open Closed Detector Security Protection
Description:
When you leave home, it will push notification message to you when the door/window opens or closes, so you can discover the intruder in time. Furthermore, you could share the device to your family members and track the history of sensor activities.
Easy to Install:
No complicated installation tools are required. The sensor can be installed with double-sided adhesive tape or screws(included) in just a few steps, and download an app "tuya" or "Smart Life" from GooglePlay or App Store to add the device to detect the status of your door/window.
Specification:
*App/Platform: Tuya / Smartlife APP
*OS Support: IOS8.0 / Android4.0 and above
*Working Frequency: 2.4GHz
*Battry: DC3V CR123A lithium battery (BATTERY INCLUDE)
*Wireless distance:Max 50 meters (Empty area)
*Detecting distance: ≥20mm
*Operating Temperature: -10℃~+55℃
*Operating Humidity: Maximum 95%RH
*Wireless technology: Zigbee 3.0
*Installation method: stick on the window/door surface
(Please wipe the dust off the surface before installing our products)
Product Include:
1 * Tuya wifi door/window sensor
1 * DC3V CR123A lithium battery
Notes:
*The product needs working with Tuya zigbee gateway(host / hub)
*ZigBee device needs to use ZigBee gateway to connect to APP and push information.
*The gateway needs to be purchased separately, if necessary, please contact with us.
Multi Scenario Application
Stick-on installation, can be installed on various doors, windows, drawers, etc., achieving smart home security
Real-time Remote Monitoring
Real-time detection of the opening/closing of the doors and windows.
When the triggering distance is>20mm, a "Door Alarm" will be issued;
When the door is closed, issue 'Closing reminder'
App Notification
When the status of doors and windows changes, the mobile APP will receive real-time notification, to help us deal with any sudden situation.
Tamper Alarm
The sensor is built-in tamper switch, which provides an immediate alarm in case of illegal removal and pushes the message to the APP
Smart Power Saving
Low power consumption, 3 years of long battery life
Low Power Warning
When power is low, the sensor will push messages through Tuya/Smart Life to remind you to replace battery in time
Scene Linkage
Smart home can be achieved by linking with various Zigbee devices through the Zigbee gateway
Exquisite Details
Minimalist design, acrylic material, replaceable battery
Easy to Install
Simply remove the double-sided sticker and stick it where needed to complete the installation, without destroying the original home structure and appearance
