Meross WiFi Smart Dimmer Switch Single Pole WiFi Light Switch for Dimmable LED Work with HomeKit Alexa Google Home SmartThings
  • Model Number: MSS560 (Aliexpress Edition)
  • Brand Name: meross
  • Origin: Mainland China
  • Input: 120V~, 60Hz
  • Output: 120V~, 60Hz 400W max. for INC 150W max. for CFL&LED
Upgrade your home lighting experience with the Meross WiFi Smart Dimmer Switch Single Pole, a versatile and intuitive solution designed to give you complete control over your dimmable LED lights. This smart WiFi light dimmer switch seamlessly integrates with popular smart home platforms such as Apple HomeKit, Amazon Alexa, Google Home, and SmartThings, making it an essential addition to any smart home setup.
  • Button: 1 x On/Off button: Press and hold for 5 seconds to initiate factory reset process 2 x Brightness button 1 x Reboot button
  • LED: 1 x Status LED 5 x Brightness LED
  • Dimensions ( W x D x H ): 1.7 x 1.5 x 4.1 in. (without wall plate) 2.8 x 0.2 x 4.7 in. (wall plate)
  • Certifications: FCC, IC, ETL
  • Package Contents: 1 x Smart Wi-Fi dimmable switch 1 x Faceplate 4 x Wiring nut 2 x Screw 1 x User manual
  • Voice and App Control: Works with Apple HomeKit, Alexa, Google Home, and SmartThings for seamless voice and remote control.
  • Customizable Dimming: Fine-tune light brightness levels for the perfect ambiance.
  • Scheduling and Automation: Set schedules and timers via the Meross app for automatic light adjustments.
  • Easy Installation: Quick and simple installation process with no hub required.
  • Safety First: Overheat and overload protection for secure and reliable operation.
Neutral Wire is Required: Single Pole Dimmer Switch needs a neutral wire to connect to your existing wires. Only Support 2.4GHz WiFi.
  • Brightness Control: Set brightness from 1% to 100%
  • HomeKit Integration: Control in Home app or Meross app
  • Remote Control: Any where, any time, at your finger tips
  • Voice Control: Support Alexa, Google, Siri, just ask.
  • Smart Scenes: Set up leave home, arrive home, good night, good morning
  • Timer Schedule: Sunrise and sunset as you wish
  • High Compatibility: Compatible with various bulbs via software adjustment
  • LED Multi-mode: Turn off the LEDs to stop the glare at night
  • No Hub Needed: Direct connection to 2.4GHz WiFi.
Standard Size: Designed to match standard electric boxs. A perfect replacement for conventional dimmer switches.
Timer Setting: Schedule the smart switch to automatically power your light on and off as needed.
Voice Control: Turn the light on and off and set brightness via simple voice commands.
Remote Control: Control your devices remotely via Meross app(no hub needed). Anytime and anywhere with internet.
