Shop MyTouchSmart Indoor In-Wall Simple Set Digital Timer (White Color)
The MyTouchSmart Indoor In-Wall Simple Set Digital Timer offers an easy and efficient way to manage your home's lighting and electronic devices. Designed for simplicity and functionality, this In-Wall Digital Timer allows you to set custom schedules for your lights and appliances with straightforward on/off programming. Whether it's for daily or weekly schedules, you can automate your home effortlessly while adding convenience and energy savings.
Key Features:
Smart Digital Timer: Easy-to-use programming with on/off schedules for daily or weekly control.
In-Wall Digital Timer: Fits neatly into your existing wall switch box for a clean, integrated look.
Wide Compatibility: Works with LED, CFL, and incandescent bulbs.
Energy Savings: Helps reduce energy usage by automatically turning lights and devices on or off according to your set schedule.
Sleek Design: The modern white finish complements any interior decor.
Benefits:
Automate lighting and appliances for added convenience.
Improve energy efficiency by ensuring devices are only on when needed.
Effortless installation and integration into your home's lighting system.
Product Specs:
Manufacturer Part #:
26893-P1
UPC:
030878268936
Color:
White
Power:
120VAC, 60Hz
Signal Frequency:
60Hz
Maximum Load:
1200W tungsten, Ballast 1200VA, 1/2 HP motor, 1800W (15A) resistive
Maximum Traveler Length:
200 ft.
Operating Temperature:
32-104°F (0-40°C)
Operating Humidity:
5-85%
Minimum Hole for Wire:
#12 AWG (0.081 dia) and #14 AWG wire
Warranty:
1-Year Limited
Simple Programming and Smart Control
This Smart Digital Timer features an intuitive interface that lets you easily program your desired schedules. Say goodbye to manually turning lights or electronics on and off—simply set the timer and enjoy worry-free automation. It's ideal for controlling indoor lights, lamps, fans, and more, ensuring your devices run only when you need them to, helping to reduce energy consumption.
Compatibility and Versatility
The Indoor In-Wall Digital Timer is compatible with LED, CFL, and incandescent bulbs, making it versatile for a variety of setups. Its sleek white design seamlessly integrates with your home’s decor, providing both style and function without being obtrusive. Plus, the timer is perfect for areas like living rooms, bedrooms, and even hallways, offering scheduled control of lights and electronics.
