Nodon Wall Switch
The NodOn Wall Switch can directly control any kind of Z-Wave® or Z-Wave Plus® compliant devices such as NodOn Smart Plug or trig scenes through a Z-Wave or Z-Wave Plus Home Automation Gateway (Gateway Mode). If you hesitate to invest in a home automation gateway, NodOn Wall Switch can control directly (as the Primary Controller) all the compatible Z-Wave® devices of your home. Later, you will be able to integrate your remote control in a home automation gateway in order to upgrade your installation.
