Optex Outdoor Dual Beam Photoelectric Detector, 130 Ft.
$173
The Optex Outdoor Dual Beam Photoelectric Detector is the perfect solution for securing your outdoor space. With a range of 130 feet, this detector uses two beams to provide reliable detection of any intruders or unexpected movement. It's easy to install and is designed to withstand harsh weather conditions, making it a durable and reliable option. The sleek design ensures that it blends in seamlessly with your outdoor décor, while the advanced technology ensures that you have the peace of mind you need to protect your property. This detector is ideal for use in residential, commercial, and industrial settings, and is perfect for anyone looking to keep their outdoor space safe and secure.
Air Detection Range Outdoor 130ft. (40m)
Beam Twin Beam
Beam Characteristics Pulsed infrared
Beam Blocking Ratio 0.99
Interruption Period 50 – 500msec
Mounting Wall / Pole
Alignment Angle ±90° Horizontal
Alignment Angle 2 ±5° Vertical
View Finder Yes
Monitor Jack for Alignment Yes
Automatic Gain Control Yes
Lightning Protection 14kV
Power Input 10.5 – 28V DC
Current Consumption 41mA max
Alarm Output N.C.
Alarm Indication LED Yes
Anti-frost design Yes
IP Rating IP65
Operating Temperature -30° F to 140° F (-35° C to 60° C)
Operating Humidity 95% max
Dimensions (W x H x D) 2.6 x 6.7 x 2.7 inches (65 x 170 x 69.5mm)
Coverage 130ft
