Philio Flood Sensor Leak Detector
$24.95
$39.95
Early leak detection: Be alerted to potential water problems before they become major issues. This water leak sensor provides valuable time to react and prevent costly..
Wireless convenience: No wires required! The sensor operates on battery power and communicates wirelessly using Z-Wave technology for a hassle-free installation
Flexible placement: Mount the flood sensor alarm on any flat surface using the included double-sided adhesive tape, or secure it permanently with screws (sold separate..
Seamless integration: The Philio Flood Sensor works seamlessly with Ezlo controllers, allowing for easy configuration and integration with your existing smart home sys..
Water Leak Flood Sensor by Philio
The Philio Flood Sensor PAT02-C is a single-function Flood sensor alarm. The water leak detector sensor sends a Z-Wave signal when flooding or a leak is detected Ezlo controller. The Philio Flood Sensor devices can be fitted to any flat surface. It can be installed either using screws or a double-sided adhesive Philio smart flood sensor. This wireless Z-Wave Water Leakage Sensor works with Ezlo Controllers for easy wireless configuration and integration with advanced home control and automation functions.
- Early leak detection: Be alerted to potential water problems before they become major issues. This water leak sensor provides valuable time to react and prevent costly damage.
- Wireless convenience: No wires required! The sensor operates on battery power and communicates wirelessly using Z-Wave technology for a hassle-free installation.
- Flexible placement: Mount the flood sensor alarm on any flat surface using the included double-sided adhesive tape, or secure it permanently with screws (sold separately).
- Seamless integration: The Philio Flood Sensor works seamlessly with Ezlo controllers, allowing for easy configuration and integration with your existing smart home system.
