Philio Smart Energy Plug-In Switch-UK
$39
  • Philio Smart Energy Plug-In Switch: Control and monitor any electrical device up to 3,000W with ease
  • Energy Monitoring Function: Track real-time power consumption to help reduce energy usage and cut costs
  • Repeater Functionality: Enhances the range and reliability of your Z-Wave network by functioning as a signal repeater
  • Remote Control: Manage connected appliances from anywhere using your smart home hub or mobile app
  • Compact and Stylish Design: The switch is designed to be unobtrusive, fitting into any standard UK socket while maintaining a sleek appearance
The Philio Smart Energy Plug-In Switch (PAN16) is a powerful and intelligent solution designed to give you complete control over your electrical devices. This smart plug allows you to remotely manage any appliance up to 3,000W, offering both convenience and energy efficiency for your home. It is more than just a plug; it also supports energy monitoring, enabling you to track the power consumption of your connected devices and optimize their usage to save on electricity bills.
This Smart Energy Plug-In Switch is designed to work as a Z-Wave repeater, ensuring reliable communication across your smart home network. By extending the range of your Z-Wave devices, the Philio Smart Energy Plug-In Switch enhances the performance and stability of your home automation system. Its sleek and compact design makes it an excellent fit for any home, blending seamlessly with your other appliances and devices.
Key Features:
  • Philio Smart Energy Plug-In Switch: Control and monitor any electrical device up to 3,000W with ease.
  • Energy Monitoring Function: Track real-time power consumption to help reduce energy usage and cut costs.
  • Repeater Functionality: Enhances the range and reliability of your Z-Wave network by functioning as a signal repeater.
  • Remote Control: Manage connected appliances from anywhere using your smart home hub or mobile app.
  • Compact and Stylish Design: The switch is designed to be unobtrusive, fitting into any standard UK socket while maintaining a sleek appearance.
Usage and Benefits:
  • Energy Efficiency: With the Energy Plug-In Switch, you can actively monitor and reduce the energy usage of high-power devices such as heaters, lamps, and kitchen appliances.
  • Smart Home Automation: The Philio Smart Energy Plug-In Switch integrates seamlessly into any Z-Wave network, allowing for enhanced automation and easy management of connected devices from your smartphone or tablet.
  • Safety and Convenience: Remotely switch devices on or off to ensure safety, even when you're not at home, and monitor usage to prevent power surges or overconsumption.
With its advanced features and ease of use, the Philio Smart Energy Plug-In Switch is the perfect addition to any smart home setup. Gain control over your energy usage and enjoy the convenience of remote device management with this innovative solution.
