Shop Philio Smart Energy and Humidity Sensor BrandSmart Outlet
The Philio Smart Energy and Humidity Sensor BrandSmart Outlet is a cutting-edge solution designed to bring convenience, energy efficiency, and home automation to your fingertips. This smart outlet not only allows you to control your devices remotely but also monitors energy consumption, providing real-time feedback on how much power your appliances are using. With a built-in energy meter, the Philio Smart Energy Plug-In Switch helps you make smarter decisions to reduce power usage and save on electricity bills.
The outlet is equipped with both energy and humidity sensors, giving you detailed insights into your home's environment. Easily control appliances such as lamps, kitchen ovens, or heaters using the Vera app, no matter where you are. The ability to remotely manage devices means you never have to worry about whether you left something running. The Energy and Humidity Sensor BrandSmart Outlet is also compatible with Z-Wave networks, including Ezlo Shop, and functions as a repeater, ensuring that your smart home system stays connected and responsive.
Key Features:
Energy and Humidity Sensor BrandSmart Outlet: Monitor power consumption and humidity levels, giving you detailed control over your home’s energy use and environment.
Philio Smart Energy Plug-In Switch: Remotely control and manage appliances from anywhere using the Vera app.
Built-In Power Meter: Track real-time energy consumption for smarter energy management.
Z-Wave Compatibility: Functions as a repeater in Z-Wave networks, ensuring extended range and reliability.
Remote Control: Switch off appliances like lamps or ovens directly from your smartphone while at the office, on vacation, or away from home.
Usage and Benefits:
Energy Efficiency: Reduce electricity bills by tracking and controlling the energy consumption of connected devices.
Home Automation: Easily manage multiple appliances remotely through the app, bringing convenience and peace of mind.
Smart Home Integration: Works seamlessly with Z-Wave networks and devices, including Ezlo Shop, for comprehensive smart home control.
Safety and Control: Prevent overheating or overuse by turning off devices remotely, ensuring safety for your home and appliances.
