Seco-Larm Enforcer Overhead Door Magnetic Contact, Closed Loop
$17.95
The Seco-Larm Enforcer Overhead Door Magnetic Contact is a high-quality security solution that ensures the protection of your property. Its closed loop design guarantees that the contact will only activate when the door is closed, providing an added layer of security. This magnetic contact is designed specifically for use with overhead doors, making it the perfect choice for businesses that want to secure their property without compromising on style. Its compact and durable design means that it can withstand harsh weather conditions and remain effective for years to come. The Seco-Larm Enforcer Overhead Door Magnetic Contact is easy to install, making it a cost-effective solution for any business that needs to secure their property. Invest in the Seco-Larm Enforcer Overhead Door Magnetic Contact today and enjoy the peace of mind that comes with knowing your property is secure.
Product Specs:
| Alarm Circuit | Three-wire N.O./N.C. Contact for either closed or open circuit alarm systems |
| Reed Switch | Gold under-plating with deactivated rhodium outer-plating |
| Switch Housing | Weatherproof die-cast aluminum |
| Magnet | Extra-strength Alnico 5 |
| Wire | 24 inches (61 cm), stainless-steel enclosure |
| Contact Lifetime | 50 million cycles |
| Rating | 0.02Amp./100VDC (max.), 0.2Amp./10VDC (max.), 3W (max.) |
| Operating Temperature | -15 to 160 degrees F (-25 to 70 degrees C) |
| Dimensions | 4-3/8 x 1-3/4 x 7/16 inches (111 x 44 x 11 mm) |
| Gap | 2-3/4 inches (70 mm) |
| Listings | UL, RoHS |
