Seco-Larm Enforcer Overhead Door Magnetic Contact, Open/Closed Loop
$22.95
The Seco-Larm Enforcer Overhead Door Magnetic Contact is a reliable and durable security solution for your overhead doors. Featuring both open and closed loop options, this magnetic contact can be used to monitor the status of your doors and provide an alert if they are opened unexpectedly. The contact is easy to install and can be used with a variety of security systems for added protection. With its rugged construction and reliable performance, the Seco-Larm Enforcer Overhead Door Magnetic Contact is an essential component for any secure building.
Product Specs:
| Alarm Circuit | Three-wire N.O./N.C. Contact for either closed or open circuit alarm systems |
| Reed Switch | Gold under-plating with deactivated rhodium outer-plating |
| Switch Housing | Weatherproof die-cast aluminum |
| Magnet | Extra-strength Alnico 5 |
| Wire | 24 inches (61 cm), stainless-steel enclosure |
| Contact Lifetime | 50 million cycles |
| Rating | 0.02Amp./100VDC (max.), 0.2Amp./10VDC (max.), 3W (max.) |
| Temperature | -15 to 160 ° F (-25 to 70 ° C) |
| Dimensions | 4-3/8 x 1-3/4 x 7/16 inches (111 x 44 x 11 mm) |
| Gap | 2-3/4 inches (70 mm) |
| Listings | UL, RoHS |
