Seco-Larm Enforcer PC Board for Access Control Power Supply
Regular price $87.95
Regular price $87.95 Sale price
The Seco-Larm Enforcer PC Board for Access Control Power Supply is an essential component for any security system. This high-quality board provides reliable power to your access control devices, ensuring that they operate smoothly and efficiently. With its compact design and easy installation, this PC board is perfect for both residential and commercial applications. It features multiple input and output options, giving you the flexibility to connect a variety of devices to your security system. Whether you're looking to upgrade your current system or build a new one from scratch, the Seco-Larm Enforcer PC Board for Access Control Power Supply is the perfect choice for all your security needs.
Input Voltage: 110 to 240VAC
Output Voltage: 12 or 24VDC selectable via DIP switch
Adjustable Output Voltage Range: 11 to 15 at 12VDC setting, via VR switch; 23 to 26 at 24VDC setting, via VR switch
Number of Outputs: 1
Supply Current: 5A at 12VDC / 4.5A at 24VDC
AC Input Fuse Rating: 3.15A (glass fuse)
LED Status Indicator: AC input (Green), DC Output (Red)
End-of-Line Resistor (EOL): Selectable ON (2.2 KO) or OFF via DIP switch
AC-Fail Relay Delay Timer: Selectable at 5 seconds, 5 minutes, or 5 hours via DIP switch
Supervision Relays Contact Rating: 3A at 24VDC Dry Relay Output
