Sensative Strips Drip
This Z-Wave Plus ultra-thin water, temperature, and light sensor notifies you when leaks or freezing water temperatures are detected, as well as ambient room temperature and light levels. The miniscule design of this sensor allows it to be installed where other leak sensors can't fit, ensuring that you have the most complete safety coverage within your home. Once the smallest drop of liquid is detected, or water temperatures drop into freezing levels, the Strips Drip will send a signal to your Z-Wave controller to notify you of the potential danger.
